WinUae 4.0.1
Forum News Room Actualités WinUae 4.0.1
  • Ce sujet contient 2 réponses, 2 participants et a été mis à jour pour la dernière fois par Zarnal, le il y a 6 années et 7 mois.
  • #37215
      Une petite brève pour vous annoncer que Toni Wilen vient de publier ce soir même la version 4.0.1 officielle de WinUae. Il s’agit principalement d’une release technique corrigeant les inévitables défauts de jeunesse de son ainée et apportant quelques nouveautés comme par exemple la possibilité d’insertion d’une image noire pour la VSYNC en 100 ou 120Hz. Voici le détail des corrections et nouveautés :
      4.0.0 bugs fixed:
      – Enabled “Minimize when focus is lost” option caused crash in some situations.
      – 64-bit FPU mode always changed back to 80-bit if config file was loaded.
      – 80-bit native FPU mode FREM and FMOD returned wrong results.
      – RTG statefile restore didn’t restore screen state completely.
      Other bugs fixed:
      – “Minimize when focus is lost” incorrectly activated when switching modes in some situations.
      – “Minimize when focus is lost” minimized main emulation window when GUI was open and main window lost focus.
      – If CPU panel FPU mode select menu was active and then some other panel was opened: JIT was switched off.
      – CD audio play from real/virtual CD (not from directly mounted image file) didn’t restart correctly if audio settings changed.
      – Only some emulated SCSI controllers flashed CD led when emulating a CD drive.
      – Input.keyboard_type was always read as Amiga keyboard. If PC layout was set as default, keyboard layout was read incorrectly from config file.
      – Amiga reset during active RTG rendering in RTG Multithread mode could have caused a crash.
      – RTG Multithread mode display refreshing was unreliable in 8-bit modes when palette changed.
      – Finally fixed corrupted drag and drop graphics in Harddrives and Disk Swapper panel.
      – When inserting previously connected USB input device, previous device type (Gamepad, CD32 pad etc) and autofire mode (if any) was not restored.
      – Clipboard sharing could have attempted to transfer data to Amiga side after program had taken over the system, possibly overwriting memory.
      New features:
      – Environmental variables (%variable%) in paths are not anymore resolved immediately when config is loaded but only when needed without modifying original path, preserving original path if config file is saved again.
      – Added full statefile absolute/relative path support. Loading statefile will restore correct paths even if absolute/relative path mode was changed after saving the statefile.
      – D3D9 and D3D11 VSync mode (both lagless and standard) 100/120Hz support with optional black frame insertion.
      – 68060 FPU was not disabled after soft reset if 68060 was configured without emulated 68060 accelerator board, causing reset loop.
      Pour la récupération, cela se passe sur le site officiel :
      http://www.winuae.net/download/
      Zarnal.
    • #37222
        Merci pour la news @Zarnal.  :good:   :good:   :good:
        #37231
          Cela m’a donné l’occasion d’un premier test. :-p
          J’ajoute qu’un souci technique concernant la version WHDLoad de Quick the thunder rabbit avec un processeur >68030 a été réglé. Ce n’est pas précisé dans le changelog.
